The engine cranks but will not turn over. Had a new coil put in and still does not start.
I went to the store, started fine, then another place, started fine, after the third place I stopprd, it wouldn't start after that.
Thank you for your time.
SPONSORED LINKS
Monday, October 20th, 2008 AT 10:14 AM
FRAN
MEMBER
I have a 1998 jeep 6 cyl had similar problem. I had no spark and no fuel pump and my amp and fuel gauge didn't move when I turned the key on, see if that happens to u if so unplug cranksensor see if gauges work
