1996 Jeep Cherokee Jeep only starts if gas is pressed while
MATTCHEW6
  • 1996 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 160,000 MILES
I am having an issue in that my Jeep will not start unless I press the gas while turning the key. It also will often not idle and would not stay running if I let go of the gas, while other times it will stay idle after starting up and pressing the gas and drives just fine. I brought it to a local mechanic who saw the same issues and seemed to think it may be a problem with the CPU, but I wanted to see what some other options to check into, as the mechanic was unable to find a used CPU to use and this could be a costly repair. Thanks in advance!
Thursday, November 6th, 2008 AT 4:22 PM
BMRFIXIT
  • 19,053 POSTS
I would check idle air control valve and clean throttle body as a 1st step
do you have any codes or check engine light on
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Friday, November 7th, 2008 AT 7:02 AM
