1996 Jeep Cherokee fuel problem
PROCAR55
  • 1996 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 211,321 MILES
Jeep runs for 10-15 mins. Then cuts off. No fuel, if I let it sit 2-3 hours it will start and do the same thing.I changed the fuel filter
Wednesday, May 19th, 2010 AT 1:23 PM
LEGITIMATE007
  • 5,121 POSTS
Have them check/change the cam position sensor.
Wednesday, May 19th, 2010 AT 2:38 PM
INTERNETMECHANIC
  • 700 POSTS
Use a gage and check fuel pressure. Around 49 psi. After turned off, the pressure shouldn't drop below 24 psi for at least 5 minutes.
Can you check for any applicable mil codes? Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. It may not be a fuel issue, but, you got to start somewhere.
Wednesday, May 19th, 2010 AT 2:42 PM
LEGITIMATE007
  • 5,121 POSTS
Is there a check engine light on?
Wednesday, May 19th, 2010 AT 8:22 PM
