1996 Jeep Cherokee Fuel filter replaced, now my engine won'
LAWLJEFF
  • 1996 JEEP CHEROKEE
  • 6 CYL
  • 150,000 MILES
I replaced the fuel filter on my jeep today, and after I replaced it and everything was reconnected I started it up to see if I had done it correctly, and my jeep started fine. I turned it off and let it sit for about 30 mins while I replaced a headlight wiring harness, and whenever I tried to start it again it wouldn't turn over. It sounds like its out of gas. Any suggestions/questions? I need help, please.
Wednesday, August 12th, 2009 AT 8:45 PM
  • 31,937 POSTS
Hi there,
best to test for fuel flow, undo the filter and see if you have pump pressure, hook up a hose and place it in a container turn on ignition and see if you get the pump to cycle.
Mark (mhpautos)
Wednesday, August 12th, 2009 AT 8:49 PM
LAWLJEFF
The pump is working fine.
Okay, I thought the fuel filter I put in might have got clogged or something, so I replaced the fuel line that goes from the gas tank to the fuel filter, and I put another fuel filter on. The same thing happened. It ran just fine for an hour or so, and I drove it to work, and then when I came out to start it a couple hours later it wouldn't start and it sounds like there is no gas.
Saturday, August 15th, 2009 AT 12:27 PM
  • 31,937 POSTS
When it wont start you will have to check the fuel pressure, injection pulse and spark, and go get a scan done as well, do this next.
Mark
Saturday, August 15th, 2009 AT 7:12 PM
