1996 Jeep Cherokee engine fails then wont start
PADDY COREA
  • 1996 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 180,000 MILES
Jeep engine fails then wont start usually after driving for about 20 mins. It cranks very well but no ignition.
several times it cut out and cut right back in while driving.
Saturday, September 26th, 2009 AT 2:36 PM
JDL
  • 16,098 POSTS
Welcome to the forum. When the vehicle refuses to restart, have a helper crank it, while you check for spark at the plugs. If no spark, check for primary voltage at the coil and injectors, engine cranking. If nothing, check the voltage and ground circuits at the asd relay. My first thought was a crank or cam sensor issue, but, you need to do some testing.
Saturday, September 26th, 2009 AT 2:59 PM
