Doesn't want to start right away. I have to press on the throttle a little to get it to start. Which is wrong because it is fuel injected. Once it starts, it takes approximately 3 to 4 minutes to run at an idle where it will not stall, then it runs normal. I changed the ful filter first. Then I changed the fuel pump and the fuel filter pickup filter. Currently wondering about the fuel pressure regulator.
SPONSORED LINKS
Wednesday, January 16th, 2008 AT 3:37 PM
