1996 Jeep Cherokee car turns over but will not start
LHALE
  • 1996 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 16,500 MILES
Put a fuel pump in car but still wont go
Wednesday, February 25th, 2009 AT 1:53 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Wednesday, February 25th, 2009 AT 3:31 PM
