1995 Jeep Cherokee clutch
JOSEPHMCMURROUGH
  • 1995 JEEP CHEROKEE
Engine Mechanical problem
1995 Jeep Cherokee Four Wheel Drive Manual 140000 miles
hi when I first get in and drive the jeep the clutch is normal, but after about 15 minits it starts geting harder to get it in gear, reverse is very hard with a lot of crunching, then ill get in it next morning all is ok again, then after 15 minits starts again can you tell me whats up please
Monday, September 6th, 2010 AT 6:20 AM
  • 31,937 POSTS
Hi there, first thing to check is that the clutch fluid is ok, if low top up and re bleed the system, how far do you lift the pedal before drive starts to take up?
Mark (mhpautos)
Monday, September 6th, 2010 AT 6:24 AM
