1994 Jeep Cherokee Possible Carb Problems
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
SANJO
My old six runs great still but now when the engin is cold it jerks when I let off the gas and the rpms don't come down as normal. After 20 minutes or so when the motor warms up the problem goes away and it runs fine.
Don't know if I have choke or vacuum leak issue or what. Suggestions please.
Thanks
Dec 10, 2008 at 5:16 AM
DOCFIXIT
  • 18,828 POSTS
Hi
You have fuel injection by throttle body most likely is temp sender for engine control. Located on thermostat housing front engine. It tells comp. engine is cold and richens fuel mix.
Dec 10, 2008 at 8:20 AM
