1988 Jeep Cherokee carb intake vs fuel inject
1988 JEEP CHEROKEE
BREWSTAR58
Engine Mechanical problem
1988 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 165k miles
Q.~how hard is it to change over the intakes from carb to fuel inject w/all else being the same.I have an' 88 w/258 inline 6cyl.~found a motor which same,but has carb.--want to use the carb motor,but need to switch it to fuel inject.
Dec 9, 2009 at 1:08 AM
BLACKOP555
  • 10,386 POSTS
but a fuel injection kit from jc whitney or summit racing.
it wont be efi on most cases unless you cut off your arm and leg.
it will be a throttle body injected kit.
easy job just expensive
Dec 9, 2009 at 1:13 PM
