1988 Jeep Cherokee Fuel Pump Access
SAGUM
Is there a way to sccess the fuel pump without taking the tank out?
Jul 15, 2007 at 7:07 AM
DPWD23
  • 136 POSTS
You have to either drop the tank, or cut the brush pan (that protects the fuel tank) to gain access to it.
Put the rear end up on jack stands or ramps, and block all possable movement, and you can access the fuel pump from the front of the fuel tank.
Remember to use a BRASS punch to remove the lock ring, and make sure everything is cleaned up before removing anything. Last thing you need is dirt in the tank.
Jul 18, 2007 at 3:48 PM
Suggested Repair
Access the fuel pump by dropping the tank or cutting the brush pan that protects it. Raise and securely support the rear, approach the pump from the front of the tank, use a brass punch on the lock ring, and clean the area before opening the tank so dirt cannot enter.
Conversation Summary
The owner of a 1988 Jeep Cherokee asked whether the fuel pump can be reached without removing the tank. The expert said the tank must be dropped or the protective brush pan cut for access. With the rear safely raised and blocked, the pump can be reached from the front of the tank; a brass punch should be used on the lock ring and the area cleaned first to keep dirt out of the tank.
