After about an hours drive of the slight stuttering
I parked the vehicle and later went to drive it again only to find the stuttering had gotten worse. It had become undrivable.
I took it around the block to see if the problem would clear up since I hadn't allowed much time for the water removal to do its job. Upon taking this short trip I was hit with a Red check engine light.
I just replaced the timing belt and clutch in this vehicle. And at the time the timing seemed fine.
I am at a loss to what it might be other then the fuel pump which is what I thought at first but now I am not so sure.
Any clues to what this might be other then an old car with a lot of miles acting up on me?
SPONSORED LINKS
Saturday, July 10th, 2010 AT 11:24 AM
