Recently my 'Check Engine' light came on, so I knew something was up, but the car performed fine. A few days later I noticed the engine would 'stutter' occasionally while running. I could be cruising at 60mph on the highway and it would suddenly stutter and lose power, and then, a moment later it would kick in and be back to normal. It also does this sometimes when I'm just idling at a stoplight. Same thing: stutters as if it's going to stall, and then without any prompting from me, the engine revs itself and goes back to normal. I look through my repair manual and it seems it could be one of several things, so I wonder if you can reduce the possibilities for me. Also, does my jeep have the diagnostics cable for electronic diagnosis? Where would it be located? My neighbor has one of those devices.
SPONSORED LINKS
Friday, November 27th, 2009 AT 10:09 AM
