Do you have a check engine light? If so get the computer scanned for for code/s-sounds like its running rich
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
SPONSORED LINKS
Tuesday, August 11th, 2020 AT 6:26 PM
(Merged)
