Welcome to the forum. I'd check the circuits at the fuel pump relay. Voltage to the load/switch side of relay, I believe is hot all the time. Voltage to the coil side of relay, may go hot when you turn on the key. The ground for the coil side of relay, is controled by the pcm.
SPONSORED LINKS
Saturday, January 30th, 2010 AT 2:09 PM
