1990 Jeep Cherokee won't fire
FLEETWOOD94
  • 1990 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 180,000 MILES
We just replaced head gasket on this 1990 cherokee now the pos won't start It will crank but won't spark and fire up
Monday, August 11th, 2008 AT 12:22 AM
You sure the valve and ignition timing is correct when you reinstall the cylinder head? Could be the problem if not do below
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil, distributor pick-up coil, ignition control module, cam and crank sensors-
Monday, August 11th, 2008 AT 2:00 AM
