The problem initially started with: Would start but would die within 30 secs. After replacing fuel pump, filter and regulator, air filter, TPS, IAC, Map sensor and fuel relay it wouldn't start. It would crank, just not ignite... the plugs, distributor, cap/rotor, wires and coil are all new. Now, as I have said, it will turn over, won't start and now it has burned the ballast wire that connects to the starter relay. which is also new. What else haven't I replaced and could it be a ground issue? If so, where would the issue more than likely be? I hope I've explained this well enough. This is my DD and I really need it up and running. Thanks for your suggestions.
Jul 1, 2010 at 2:15 PM
