1989 Jeep Cherokee Wont Start
MSMOORE24927
  • 1989 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 209,211 MILES
I have don't just about everything possibe. I tested everything and still can't find the issue. I Don't know what to do. I cranks normally but wont turn over. Also I can't figure out why my injectors aren't firing. I need some help let me know anything possible to get this car on the road.
Tuesday, November 4th, 2008 AT 8:11 PM
HUBBAZOOT
  • 7 POSTS
I had a similar problem in my 1987 jeep cherokee. If I put it in gear (manual transmission) and rocked it back and forth, I could get it to start. I would check the starter relay. If it makes a clicking sound when you try to start it (even after it turns over a couple times) it could be a low battery, in which case all you need to do is get a jump start.
Monday, November 10th, 2008 AT 12:04 AM
BRADENCJONES
Try these two things
1- pick up cord(under the distributor cap)
2- crankshat positioning sensor(on the transmission)
that fixed my problem for 5 months.
Unfortunantly it went out today!
Now I need to find out what made it go out again?
If works email me at bradencjones@yahoo. Com
or if you find something else out please send info
best luck!
Wednesday, November 19th, 2008 AT 11:45 PM
