1992 Jaguar XJS Overheating
1992 JAGUAR XJS
43,000 MILES • V12 • 2WD • AUTOMATIC
DAVE O
I understand that the problem with overheating is very common in my model of Jaguar.
What is the answer??
The temperature will start off at normal until about 10 miles have been driven, then slowly creep up into the red!!
Mar 29, 2008 at 9:04 PM
BLACKOP555
  • 10,386 POSTS
your thermostat may be bad, also make sure your fans are the radiator fans turning on when the vehicle gets warm and turns over to hot?
you may have a plugged cooling system and a bad radiator also.
Mar 30, 2008 at 1:41 AM
