engine Overheating
205,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
ALEXIS SALIS
My car needs your help. overheating, no leaks, coolant spills from overflow tank when you turn engine off, no coolant in oil, new top on overflow tank. gauge shows overheating, never let it get on red, little white smoke at times from tail pipes. Runs perfect until needle get to "N" then it starts missing at first then the overheating, it heats up more when is on the move than when is idle. Any ideas? Please!
P.S. New water pump and new thermostat
Apr 25, 2017 at 11:43 PM
HMAC300
  • 48,601 POSTS
check coolant system with a pressure checker for a head gasket problem. there is also a chemical you can add to coolant sold at auto parts that will check as well. also, when engine is hot, disconnect fans if electric and check radiator for cold spots there should not be any it should be same temperature all over as well as corrosion/greenish color usually at bottom or sides.
Apr 25, 2017 at 11:49 PM
ALEXIS SALIS
I will test for gasket. Hope is not it!
Apr 26, 2017 at 1:33 AM
  • 55,627 POSTS
Cheers, Ken
Apr 29, 2017 at 7:33 AM
