vanden plas traction control
STEVEN SOLDINGER
1999 Vanden Plas V8 XJ8
I can be driving along and the traction contol failure message comes on and the engine goes into a engine fail safe mode which allows the car to stay on and move at an idyle speed. Does not allow for acceleration. It happens intermitently and it can be first thing in the morning or anytime at all. Happens with no notice and no pattern. Dealer can not find any problem. I can turn the car off when it goes into this fail safe mode and it then most of the time resets and I can either drive some more or it triggers the same and without notice goes into the mode once again which leaves me in traffic shutting down the vehicle and starting it up once more. This is very dangerous and jaguar should care enough to . address. The car has 73,000 miles and this has been going on since 40,000 miles. Please help me.
Nov 6, 2007 at 12:31 AM
DAVE H
  • 13,383 POSTS
It sounds like you have an ABS wheel speed sensor that is out here is a video that will show you how to find out which one.
https://youtu.be/rTtAnsOlZU4
if you don't have a scanner here is a guide to test it by hand.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Please run down these guides and report back
Cheers
Nov 26, 2009 at 12:09 AM
TJ SR
I ran the codes it told me the right front ABS sensor had gone out I replaced it for $42.00 and all fixed :) I love this site.
Jul 14, 2018 at 11:40 AM
