1999 Jaguar XJ8 ABS Stability Failure Fix
BOBANDERSON
My car has 49,000 miles and has developed an intermittent failure of the ABS/stability control system. The indicator reads "stability control failure" and the ABS symbol also illuminates. The failure tends to occur after the car has been driven on a hot day, then stopped for about one-half hour, parked in the sun, and restarted. Once the failure occurs during a day, it tends to remain for the rest of the day (but not always). The failure always resets overnight and never occurs when the car is first started in the morning. We got the car to the dealer once when the failure was occurring (because ABS codes are not stored in the ECM), and they said the ABS code indicated failure of the ABS module ($1,300.00). This code can also indicate failure of the ABS unit $1,600.00). The service adviser noted that the ABS module can become "confused" and to recommended we ignore the failure as long as it resets overnight. I have tested the ABS unit (in the rain) and it works just fine. I have inspected and cleaned the four ABS wheel sensors. I am guessing an intermittent of some sort in the ABS module. Any ideas?
Apr 3, 2006 at 12:52 PM
2CARPRO JACK
  • 11,533 POSTS
Electronics are funny that way. If it does it hot then a module problem is likely.
Apr 6, 2006 at 10:08 AM
LEE3393
I have read posts on other forums that have had this corrected by removing the negative from the battery (in trunk) this resets the abs control module these cars have about six different modules for different systems and sometimes the connections can get corroded as well. The US market cars will not lose their radio codes when battery is disconnected.
Jun 28, 2007 at 6:50 AM
FSTRANGER302
  • 117 POSTS
hello, you have already determined your problem. the pump operated fine. that leaves only the module. yes, it is expensive to fix. try to find a used one they do not need to be programmed. just plug in and drive.
Sep 20, 2007 at 3:01 PM
PRFR
Hi, I had this problem earlier this week, I was quoted £1000+ by the main dealer over the phone before he had even looked at the car.
What I did was remove the wheels and the ABS sensor is easily located, it has a 2 pin plug connecting it to the lectrics, disconnect it, get a multi meter and test the resistence of the sensor, it should be around 650 ohms, the lowest I had was 615 ohms and the highest was 658 ohms except for the one that was open circuit!
A new one from Jaguar is £147.95, a used one from my local Jaguar specialist was £20.
Apart from struggling a bit to get the old one out, it's was easy enough to replace.
Dec 19, 2007 at 2:15 AM
Suggested Repair
Because the fault appears when hot and the pump still works, replace the ABS control module. A used module can be installed without programming; plug it in and drive.
Conversation Summary
A 1999 Jaguar XJ8 with 49,000 miles has an intermittent ABS and stability-control failure that appears after hot-day driving and a sun-soaked stop, then usually resets overnight. The dealer retrieved an ABS code pointing to the module or ABS unit. Experts said a heat-related module fault is likely and recommended a used plug-and-play module. Another owner reported a similar warning caused by an open-circuit wheel-speed sensor.
