2004 Jaguar XJ8 Oil Pan Cover Screws
KOOLWHITECAT
I have a 2004 XJ8. i need to remove the cover panel beneath the car to get to the oil pan and filer. i remove most of the screws and able to see the filer and oil pan. however, there 3 screws (a round 1inch in diameter with a tiny hole in the middle) left i cann't figure out how to remove them.
please help.
thanks
Apr 13, 2006 at 6:26 AM
2CARPRO JACK
  • 11,533 POSTS
try prying them up, they might be push buttons
Apr 25, 2006 at 9:50 AM
FSTRANGER302
  • 117 POSTS
there are two nuts in the center, some have three bolts in the front and 4 in the back. also it has two screws inside two holes in the front remove all the above and the cover will falldown
Sep 20, 2006 at 2:03 PM
KOOLWHITECAT
That was it! thank you "fstranger302".
[quote:9e50e827e1="fstranger302"]there are two nuts in the center, some have three bolts in the front and 4 in the back. also it has two screws inside two holes in the front remove all the above and the cover will falldown[/quote:9e50e827e1]
Sep 21, 2006 at 3:48 AM
Suggested Repair
To drop the underbody cover, remove the two center nuts, the front and rear bolts (often three in front and four in back), and the two screws inside the front holes. The cover should then fall down.
Conversation Summary
The owner of a 2004 Jaguar XJ8 could see the oil pan and filter after removing most underbody cover screws, but three large round fasteners with tiny center holes remained. One reply suggested prying possible push buttons. Another said to remove two center nuts, the front and rear bolts, and two screws inside front holes so the cover falls down. The owner confirmed that advice worked.
