1998 Jaguar XJ8 Startup Clicking
THUNDERCAT
:roll: I am trying to change the oil in my 1998 Jag but I can't seem to remove the oil drain plug. Also it is making a horrible clicking noise when I first start it, then it goes away after a few minutes. What could this be? Thank you.
Apr 22, 2006 at 2:15 PM
2CARPRO JACK
  • 11,533 POSTS
sounds like it slow to oil the engine. Be sure to use the manufacturer recommended oil weight
Apr 25, 2006 at 9:45 AM
FSTRANGER302
  • 117 POSTS
the noise may be the secondary tensioners the plastic will break off. need to go to dealer or qualified notice i said qualified mechanic to do if not done right will possibly cause engine damage. the drain plug should just come off unless it was cross threaded
Sep 20, 2006 at 2:24 PM
Suggested Repair
Use the manufacturer-recommended oil weight. Have a dealer or qualified mechanic inspect the secondary tensioners, since broken plastic can cause startup clicking and improper repair can damage the engine. The drain plug should unscrew unless it is cross-threaded.
Conversation Summary
The owner of a 1998 Jaguar XJ8 could not remove the oil drain plug and reported a clicking noise at startup that stopped after a few minutes. One expert said the engine may be slow to receive oil and advised using the recommended oil weight. Another said the noise may be failing secondary tensioners and recommended a dealer or qualified mechanic, warning that incorrect work can damage the engine, and noted the plug should come off unless cross-threaded.
