1998 Jaguar XJ8 Intermittent No Start
RSJ6667
I have an intermittent problem with my 1998 XJ8. The car has 47000 miles on it and has developed a strange prob. When trying to start the car.. it appears the battery is dead, but the lights and all accessories work. If I let the car sit for a couple hours it will start. If I try to restart it again it acts as though the battery is dead.. just a click when I turn the key. The battery is about 3 yrs old. I am wondering if a defective battery could be causing this ... or some problem with the security system.
Jul 19, 2007 at 8:36 AM
FSTRANGER302
  • 117 POSTS
[quote:00271dea43="rsj6667"]I have an intermittent problem with my 1998 XJ8. The car has 47000 miles on it and has developed a strange prob. When trying to start the car.. it appears the battery is dead, but the lights and all accessories work. If I let the car sit for a couple hours it will start. If I try to restart it again it acts as though the battery is dead.. just a click when I turn the key. The battery is about 3 yrs old. I am wondering if a defective battery could be causing this ... or some problem with the security system.[/quote:00271dea43]
hello, it sounds like you have a relay issue for the starter. i have not seen to many starters go bad in this model car, but not saying it couldnt happen. seen a couple go bad. i have seen more relays thant starters, the relays are on the pass side of car under the plastic cover in the cool box. 4 screws are holding cool box cover down. but you will have to figure out which relay is the starter relay. hold your hand on the relays and have someone turn the key the relay will click and unclick when key is released.
if the relay clicks and unclicks then it is probaly the starter. hope this helps
Nov 19, 2007 at 11:58 AM
Suggested Repair
Check the starter relay on the passenger side under the cool-box cover (held by four screws). Identify it by feeling which relay clicks when the key is turned and releases when the key is released. If that relay clicks normally, the starter is the more likely fault.
Conversation Summary
The owner of a 1998 Jaguar XJ8 with 47,000 miles reports an intermittent no-start: lights and accessories work, but turning the key produces only a click. The car may start after sitting a couple of hours, then fail again. A three-year-old battery or the security system was suspected. The expert says this is more often a starter relay than a starter, located under the passenger-side cool-box cover, and that a relay that clicks and releases points toward the starter itself.
