1998 Jaguar XJ8 Cold Start Ticking
BUGBOY63
I have a 1998 Jaguar XJ8L. It has 90000 miles on it.
When I start the car when cold it makes a ticking noise that will go away when you rev the motor. What could be causing this?
Sep 20, 2007 at 2:37 PM
FSTRANGER302
  • 117 POSTS
[quote:858793c9ff="bugboy63"]I have a 1998 Jaguar XJ8L. It has 90000 miles on it.
When I start the car when cold it makes a ticking noise that will go away when you rev the motor. What could be causing this?[/quote:858793c9ff] hello, the noise you hear is from the timing variable valve timging circuts. this should be fixed by a dealer the job is very diificult and should be done at the dealer
Sep 20, 2007 at 2:50 PM
Suggested Repair
Have a Jaguar dealer inspect and repair the variable valve timing circuits. The cold-start ticking is attributed to those circuits, and the repair is difficult.
Conversation Summary
The owner of a 1998 Jaguar XJ8L with 90,000 miles reports a ticking noise on cold start that stops when the engine is revved. The expert attributes the noise to the variable valve timing circuits and recommends dealer repair because the job is difficult.
