2001 Jaguar XJ8 Wind Noise
MSLATON
  • 5 POSTS
I have a 2001 XJ8 and have some bizarre wind noise coming in somewhere around the front window post area on both sides of the car. It's a relatively high pitched noise similar to when you blow across the top of a long neck beer or coke bottle (sort of a soft hoot/howl if you will). I have moves the mirrors in a bit and that seems to make no difference so it doesn't appear to be that.
It seems to happen at around 70 mph. Anybody else have a similar experience? Car has less the 40k on it.
Sep 21, 2007 at 5:17 AM
MERLIN2021
  • 17,250 POSTS
ECT= electronic coolant temperature sensor!
Wind noise is all it is, you will need either new weather strip or the doors adjusted...
Sep 21, 2007 at 5:37 AM
FSTRANGER302
  • 117 POSTS
[quote:df1df3a07a="mslaton"]I have a 2001 XJ8 and have some bizarre wind noise coming in somewhere around the front window post area on both sides of the car. It's a relatively high pitched noise similar to when you blow across the top of a long neck beer or coke bottle (sort of a soft hoot/howl if you will). I have moves the mirrors in a bit and that seems to make no difference so it doesn't appear to be that.
It seems to happen at around 70 mph. Anybody else have a similar experience? Car has less the 40k on it.[/quote:df1df3a07a]hello, take some tape and tape around the base of the mirrors and then drive the car again. there is a issue with the base of the mirrors were they pivot. if this works try some weater striping around the base let me know if this helps
Sep 21, 2007 at 1:46 PM
Suggested Repair
Inspect and replace the door weatherstripping or adjust the doors. Also tape around the mirror bases and road-test; if the noise stops, add weatherstrip at the mirror pivot bases.
Conversation Summary
The owner of a 2001 Jaguar XJ8 reports a high-pitched wind howl near both front window posts at about 70 mph. Adjusting the mirrors did not help. Experts say the noise is wind-related and recommend new weatherstrip or door adjustment, plus a tape test around the mirror bases to check for a pivot-area leak that can be sealed with weatherstrip.
