Jaguar Xj6 A Lady On Jag X Type 2002
2002 JAGUAR XJ6
SHIRLS
I had trouble shifting so I took the car in. Was told that the clutch failed and was not under warranty. Had it fixed for big dollars, along with waterpump that was under warranty. Got the car back, and the same day, I had trouble shifting again and heard a funny bad noise. Had the car put on a lift by a friend who told me that the transmission was shot. Here is what friends said.
1. CV boot leaking oil.
2. Metal shavings in transmission fluid.
3. Drive shaft was so loose, could be moved by hand.
4. Oil on the bell housing.
5. Transmission fluid leaking from the differential to the driveshaft.
He also said that the differential housing had a yellow number written on it and that his experience was a that's a sign of a junkyard part. Maybe Jag lables parts this way.
Had the car towed to dealer. They are replacing the driveshaft, transmission, differential, gear box, etc, under warranty.
Questions:
1. How do I know that the real problem with the car wasn't the transmission all the time, but the dealer knew they could get money for a clutch repair out of me since clutch is not warrantied unless the failure is caused by a warranteed part?
2. Could the leak from the CV boot or other leak cause for the clutch plate to fail? If that is the case, then the clutch would have been covered under warranty.
3. How do I know if the dealer didn't mess with the transmission on purpose so that they could now get money from Jag for warranty work, after they also got my money for clutch repair.
4. How do I know if the clutch was replaced at all? On the lift, it looks as if the bolts had been loosened, but I wouldn't know what a new flywheel looked like if it hit me in the face.
4. After repairs, can I rely on this car to travel distances? I have had the car for less than 10K miles and it has less than 40K miles on it.
It seems too coincidental that the day after I get my car back, the transmission fails.
I am filing a Freedom of Information Act request with our attorney general to see if there have been other complaints lodged against the dealer for mechanic fraud. But, I need to have as much info as possible. I am suspicious. Please advise, and thanks so much in advance.
Shirls
Mar 8, 2006 at 4:30 AM
BESTGRIPAJAG
  • 13 POSTS
:( Wow i realy dont know how to help you ,but all i can say is get a second assesment all the time(another dealer) before you do anything,and learn about every detail of your car(extended manual)With some understanding of parts and how they work it might avoid future problems.However it sounds like they had one target in mind and may; i repeat may have overlooked the main problem in your case.Protect yourself with the undertanding of your car.If you sound like you know what your talking about they will be less prone to make stuff up. that goes for everyone! Good luck and all the best.
Mar 16, 2006 at 1:18 AM
FSTRANGER302
  • 117 POSTS
ask to see the parts and have them explain to you also compare the parts to new parts so you can see for yourels. you will se the clutch disc will be worn.
jag will warranty the clutch disc you need to ask for help from jaguar cars ask to speak to there district manager about the issue good luck
Sep 20, 2006 at 1:50 PM
