1971 Jaguar E-Type Clutch Won't Bleed
1971 JAGUAR
DON JONES
I've replaced both the clutch master and slave cylinders, but am unable to bleed the system. No fluid or air comes out of the slave cylinder bleed nipple. I've tried a vacuum hand held pump with no success. I appreciate any advice you may have.
Mar 14, 2006 at 9:02 AM
2CARPRO JACK
  • 11,533 POSTS
did you bench bleed the master? That could be your problem
Apr 25, 2006 at 9:55 AM
FSTRANGER302
  • 117 POSTS
try having someone hold down on the clutch pedal while tring to vacum bleed the system
Sep 20, 2006 at 2:31 PM
Suggested Repair
Bench-bleed the clutch master cylinder, then have a helper hold the clutch pedal down while vacuum-bleeding at the slave cylinder bleed nipple.
Conversation Summary
The owner of a 1971 Jaguar E-Type Coupe replaced the clutch master and slave cylinders but cannot bleed the system. No fluid or air comes from the slave bleed nipple, and a handheld vacuum pump did not help. Experts suggest bench-bleeding the master and holding the clutch pedal down while vacuum bleeding.
