2002 Other Jaguar Models Gear
2002 JAGUAR
41,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLUCAS
When shifting from Park into drive my car will not move unless I move into 3rd or the gear. All gears work properly except for drive. It seems as though that gear is stripped if that is even possible
Jan 13, 2008 at 11:22 PM
FSTRANGER302
  • 117 POSTS
[quote:4299be197f="blucas"]Transmission problem
2002 Other Jaguar Models 6 cyl Two Wheel Drive Automatic 41,000 miles
When shifting from Park into drive my car will not move unless I move into 3rd or the gear. All gears work properly except for drive. It seems as though that gear is stripped if that is even possible[/quote:4299be197f]
is your car a s type. if it is sounds like the shifter cable is stretched. nessesary to replace the shifter calble and have it adjusted. this should take care of problem. hope it helps. let me know
rep points apreciated if this helps.
Jan 19, 2008 at 5:20 AM
