1996 Jaguar XJ6 ABS Stutter at Low Speed
EMILYNELMS
I can feel the stutter of my ABS brakes at a low braking speed. This is an intermittent problem. I also hear the hum or whine of the ABS system, or what I think is the ABS system, when I'm not braking - but usually when going slowly.
Could the sensor be going bad? Any suggestions of things to look for to check out this problem?
Thanks soooo much for any help!
Jan 10, 2006 at 12:50 PM
2CARPRO JACK
  • 11,533 POSTS
This happens when a wheel speed sensor is going out, if you follow this guide it can help you find out which one is bad so you can replace it.
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/rTtAnsOlZU4
Please go over these guides and report back.
Jan 18, 2006 at 9:18 AM
Suggested Repair
Test the wheel speed sensors to identify the failing sensor, then replace it.
Conversation Summary
The owner of a 1996 vehicle reports intermittent ABS stutter during low-speed braking and a hum or whine, believed to be from the ABS system, while moving slowly without braking. They ask whether a sensor may be failing. The expert says this typically occurs when a wheel speed sensor is failing and recommends using diagnostic guides to identify the bad sensor so it can be replaced.
