1997 Jaguar XJ6-driver power seat will not work. Fuses are OK, lumbar support works. Anything else that I should be doing?
Jun 5, 2006 at 5:35 AM
Check for power and ground at the seat control switch. A failed seat module is a common cause on these cars.
The driver power seat on a 1997 Jaguar XJ6 does not work, though the fuses are good and the lumbar support still operates. One expert advised checking power and ground at the control switch. Another said a bad seat module is a very common failure on these cars.
