1992 Jaguar XJ6 Starts Then Dies
LISALISAJ
[color=darkred][/color] :roll: I have a XJ6. When I start the engine the car runs rough. Sometimes after a while it seems to work itself out and runs fine and othe times it won't stay started at all. Could the catalytic-converter cause this? Any other suggestions as to what I should check for?
Thank you
Lisa
Jun 23, 2006 at 7:16 AM
VANDRAGON
  • 298 POSTS
hey lisa,
didn't your daddy tell you if you were going to buy a jag to buy two, because one would always be in the shop. best to call autozone ask if they can scan the computer for codes, it could be a number of things. clogged air filter, fuel filter, o2 sensor, get the scan and take the guess work out....good luck girl..vandragon
Jun 25, 2006 at 2:18 AM
Suggested Repair
Have the engine computer scanned for trouble codes, then check the air filter, fuel filter, and oxygen sensor before guessing at the catalytic converter.
Conversation Summary
The owner of a 1992 Jaguar XJ6 says the engine runs rough after starting, sometimes smooths out, and sometimes will not stay running. They ask whether the catalytic converter could be the cause. The expert recommends a diagnostic scan and checking the air filter, fuel filter, and oxygen sensor rather than guessing.
