i have a 1979 series 2 XJ6. It stopped running on highway. it was running fine until then.Checked fuel pressure 10psi and replaced fuel filters. Electric fuel pumps working OK. Checked spark and it appears weak and has been running rich. ie black plugs not oily. Compression 125 psi on all cylinders. Ignition is electronic no points. Could it be weak spark from leads needing replacement or, coil or plugs? Checking plugs which are wet after trying to turn over engine which is very close to starting but then floods. Thanks for any info. Steve
1979 Jaguar XJ6 Highway Stall
Suggested Repair
Verify spark is a long blue spark rather than a short orange one. If spark is weak, test the coil and coil amplifier; plug wires are less likely unless it misses under load. Fuel pressure of 10 psi is too low: expect about 40 psi at key-on, 30-35 psi running, and about 20 psi residual pressure with the engine off. Check the fuel pressure regulator and pump delivery.
Conversation Summary
A 1979 Jaguar XJ6 Series 2 stopped running on the highway after running normally. The owner found 10 psi fuel pressure, working electric pumps, new fuel filters, weak spark, rich running with black non-oily plugs, 125 psi compression on all cylinders, and wet plugs that flood during cranking. The expert advised checking spark color and length, then the coil or coil amplifier if spark is weak, and noted fuel pressure should be much higher, pointing to a possible bad fuel pressure regulator or inadequate residual pressure.
