1996 Jaguar XJ6 Hesitation and Stalling
PLAYAJW
I have a 1996 Jaguar VanDenPlas with the 4.0 liter 6 cylinder engine with 100,000 miles. A strong runner, well maintained. However sometimes after long drives mostly during warmer weather it will hesitate when I accelerate or even stall at idle. Usually when it dies i can restart it right away, but occasionally it will immediately die. I will accelerate the engine over 3000 rpm's and then it will drop below 700rpms and die.
Like my other Jag, a 1994 XJS with a similar problem, I am assuming the Mass Air Flow Sensor, but I am not ruling out the throttle position sensor or the ignition module.
Any help would be great.
Thanks,
Jason
Jun 29, 2007 at 3:21 PM
JAMES W.
  • 2,394 POSTS
I wouldn't rule out the TPS, how about the idle speed control unit
Oct 5, 2008 at 1:01 PM
Suggested Repair
Do not rule out the throttle position sensor. Also check the idle speed control unit for the warm-weather hesitation and stalling.
Conversation Summary
The owner of a 1996 Jaguar XJ6 Vanden Plas reports hesitation, stuttering, and occasional stalling after long drives in warmer weather, usually with an immediate restart. They suspect the mass airflow sensor, throttle position sensor, or ignition module. The expert advises not ruling out the TPS and suggests checking the idle speed control unit.
