High idle
1996 JAGUAR XJ6
68,000 MILES • 6 CYL • 2WD • AUTOMATIC
DREYER XJ6
  • 7 POSTS
how can I adjust the idle on my 1996 Jaguar XJ6
Dec 28, 2007 at 7:56 PM
BLACKOP555
  • 10,386 POSTS
where the throttle cable meets the throttle body, you shoud see a screw, simply tighten the screw to increase idle.
Dec 28, 2007 at 7:58 PM
DREYER XJ6
  • 7 POSTS
ther is no screw on the throttle body to adjust?
Dec 28, 2007 at 8:13 PM
DREYER XJ6
  • 7 POSTS
[quote:c6f737e638="blackop555"]where the throttle cable meets the throttle body, you shoud see a screw, simply tighten the screw to increase idle.[/quote:c6f737e638]
Ther is no screw??
Dec 28, 2007 at 8:14 PM
BLACKOP555
  • 10,386 POSTS
if your sure of that try tightening up the throttle cable. i have yet to see a vehicle without a idle adjust screw of some sort.
Dec 28, 2007 at 10:00 PM
DREYER XJ6
  • 7 POSTS
If have looked and looked, no idle screw. I need to slow down the idle so tighting the throtel cable won't work. Any other suggestions?
Dec 30, 2007 at 2:55 PM
BLACKOP555
  • 10,386 POSTS
try cleaning out your throttle body, is the throttle as loose as its gonna get? if so thats what the idle is supposed to be.
Dec 30, 2007 at 3:23 PM
DREYER XJ6
  • 7 POSTS
the trottle body is brand new and the cable is loose. I need to slow my idle down
Dec 30, 2007 at 6:14 PM
BLACKOP555
  • 10,386 POSTS
HOW HIGH IS IT IDLING? check for rubber plugs on the throttle body the screw may be hidden. Also check for vacuum leaks
Dec 30, 2007 at 7:27 PM
DREYER XJ6
  • 7 POSTS
the is currently at 1400 RPMs, the throttle body is new. it doesen't have any plugs.
Dec 31, 2007 at 8:16 AM
DREYER XJ6
  • 7 POSTS
The throttle body is new. It doesn't have any plugs.
Dec 31, 2007 at 8:17 AM
BLACKOP555
  • 10,386 POSTS
when the car is warm does the idle go down any?
Dec 31, 2007 at 9:54 AM
