1994 Jaguar XJ6 Fuel Fail 44
DURESS8
My monitoring system shows a code: fuel fail 44 what does this code indicate?
Nov 21, 2006 at 3:26 AM
JAMES W.
  • 2,394 POSTS
according to the list 44 is an O2 sensor out of range or not reading at all. You may want to change it or have it changed. The code should clear itself if this solves the problem.
Oct 5, 2008 at 4:48 PM
Suggested Repair
Replace the oxygen sensor. Code 44 indicates the O2 sensor is out of range or not reading; the code should clear itself if replacement solves the problem.
Conversation Summary
The owner of a 1994 Jaguar XJ6 has a check engine light and a monitoring-system code of fuel fail 44. The expert says code 44 means an oxygen sensor is out of range or not reading at all, and recommends replacing the sensor. The code should clear itself if that fixes the problem.
