1984 Jaguar XJ6 Won't Start
BAILHUNTER001
I have an 84 XJ6 I picked up to restore.Former owner could not get it to start. Installed new fuel pump, filter and injecters. I have only been able to get it to start by spraying starting fluid in the intake. I do not hear any sound from the pump. I am new to jags. Could it be a relay or the MAF/AIS? Any help is appreciated.
Jun 26, 2007 at 5:20 AM
JAMES W.
  • 2,394 POSTS
Have you checked fuel pump relay? Key on, power to relay term. # 30? If no power, look for blown fuse. ck.power at term #85. No? check main relay for power in/out. I use a spare relay with the plastic cap removed. You can "see" if the relay is physically closed or can close it manually. Hope this helps.
Oct 5, 2008 at 1:53 PM
BENTLEY EVERSLEY
  • 31 POSTS
Hi there still not starting get back to me I had the same problem, may be able to help.
Jan 8, 2010 at 12:58 AM
Suggested Repair
With the key on, check the fuel pump relay: confirm power at terminal 30 and, if absent, inspect the fuse. Check power at terminal 85; if none, test the main relay for power in and out. A spare relay with the cover removed can show whether the contacts close or can be closed manually.
Conversation Summary
The owner of a 1984 Jaguar XJ6 cannot start it except by spraying starting fluid into the intake. A new fuel pump, filter, and injectors were installed, but the pump makes no sound. The expert recommends checking the fuel pump relay, related fuse, terminal power, and main relay. Another user said they had the same problem but gave no specific repair.
