1991 Xj6 Soveriegn Fuel 14 error msg
1991 ALL OTHER MAKES ALL OTHER MODELS
MILESMAYO
My 91 Xj6 wont turn over. I had the fuel pump replaced 2 months ago. The error msg reads Fuel error 14 which refers to fuel vacuum hose leak.
How serious a problem is this ? Please help..I don't want to have it towed just yet and i need to fix it asap.
May 19, 2007 at 4:53 AM
JAMES W.
  • 2,394 POSTS
A code 14 won't keep your car from turning over or starting. According to my sheet, a code 14 is "coolant temp sensor out of range" which means the CTS is usually bad. If it "won't turn over" you need to check your starting system.
Oct 12, 2008 at 4:34 PM
