1991 Jaguar XJ6 wont start
IVAN 505
  • 1991 JAGUAR XJ6
  • 6 CYL
  • AWD
  • 150,000 MILES
I wet my engine and it wont start up
Friday, May 28th, 2010 AT 5:51 PM
You probably shorted a wire out and if it's cranking over and will not start-Lets do below for a start to determine if its fuel or spark related issue and get back asap.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, May 28th, 2010 AT 5:54 PM
