1988 Jaguar XJ6 Trouble Codes
JSOUADIH
1988 jaguar xj6 71,000 miles 3.6L
i had to replace the washer reservior and trunk latch. how do i clear the trouble codes so it does not show them any more.
Feb 16, 2007 at 9:22 AM
JAMES W.
  • 2,394 POSTS
Normally after a few engine cycles the code will clear itself. You can disconnect the battery for a min. or two or connect a scan tool and erase them with that. A lot of auto parts stores will "lend" you a scan tool for this purpose.
Oct 5, 2008 at 4:35 PM
Suggested Repair
Allow the codes to clear after a few engine cycles, disconnect the battery for a minute or two, or erase them with a scan tool. Many auto parts stores will lend a scan tool for this.
Conversation Summary
The owner of a 1988 Jaguar XJ6 replaced the washer reservoir and trunk latch and asked how to clear the trouble codes so they no longer display. The expert said codes often clear after a few engine cycles and can also be cleared by briefly disconnecting the battery or using a scan tool.
