1988 Jaguar XJ6 No Start
DHAK1959
  • 1988 JAGUAR XJ6
  • 6 CYL
  • 115,000 MILES
My 1988 XJ6 will not start it tries to start then dies off. I have checked spark and air filter and gas it is getting all three but it may not be getting enough how much fuel pressure should there be after the regulator? I hear the pump run and have opened the line after the regulator and turned on the car and fuel comes out but not with a lot of force it just kinda has a quick burst then just runs out it this correct or should there be more pressure
Monday, January 11th, 2010 AT 7:42 PM
DAVE H
  • 13,384 POSTS
Fuel Pressure Release (XJ6)
Remove driver's side fuse block cover. Disconnect inertia switch wire connector (White). Start engine and let idle until engine stalls. Crank engine an additional 5 seconds.
REGULATED FUEL PUMP PRESSURE
Applicationpsi (kg/cm2 )
All Models. 35-45 Psi
Sunday, January 17th, 2010 AT 5:09 AM
