HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jaguar
Vanden Plas
Engine
Computer
Limp Mode - Reduced Power
Restricted performance message
DRPUP
MEMBER
2000 JAGUAR VANDEN PLAS
V8
2WD
AUTOMATIC
68,000 MILES
Random cylinder misfire code and cyl.1-8 misfire codes. Dealer changed MAF but no help. They do not know cause.
Saturday, January 24th, 2009 AT 1:29 PM
KEN L
MASTER CERTIFIED MECHANIC
Most of the time when a random misfire codes if the MAF doesn't fix it it will be a weak fuel pump or the engine needs new spark plugs.
Here is a guide to help you see what you are in for when changing the spark plugs
https://www.2carpros.com/articles/how-to-change-spark-plugs
I would also service the throttle body
Also scan the PCM for codes.
Please run some tests and get back to us.
Cheers, Ken
Friday, November 27th, 2009 AT 5:58 AM
DRPUP
MEMBER
1 POST
Thanks you so much for the guides I just had the spark plugs replaced so I services the throttle bore which was filthy and cleared the codes engine runs great no codes or message. Thanks again I love this site.
Saturday, November 28th, 2009 AT 5:08 AM
Please
login
or
register
to post a reply.
Related Engine Computer Limp Mode - Reduced Power Content
2000 Jaguar Vanden Plas Fault Codes Intermittant
Purchased Car, 7 Hrs Later, Short 30 Mi. Drive, Transfault Code Trac Unavailable, Asc. Went Into Fail Safe. Lost Power. Next Day Took Out, 3...
Asked by
krisgizz
1 ANSWER
2000
JAGUAR VANDEN PLAS
GUIDE
Reduced Power - Limp Mode
The computer system that controls your car has a built in safety feature called "Reduced Power" or "Limp Mode" which is designed to get the car where it is...
2000 Jaguar Vanden Plas Help
I Am Getting Codes P0332, P0010, P1384, P1642. Attached Is Video Of Another Issue.
Asked by
blackhonor9
2000
JAGUAR VANDEN PLAS
Ecm Removal
How Do I Remove My Ecm? I Have Removed The Glove Compartment And Have Access To It. Do I Need To Remove The Air Filter/holder On The Left...
Asked by
MMcGrath
1 ANSWER
10 IMAGES
2004
JAGUAR VANDEN PLAS
1998 Jaguar Vanden Plas Oil Change
I Want To Save Some $ Since This Car Is Getting Up On The Mileage. The Oil Has Been Changed At The Jaguar Dealer Every 10,000 Miles Up To...
Asked by
don213
1 ANSWER
1998
JAGUAR VANDEN PLAS
Engine Wiring Harness Connector
Next To The Pcm Connector At The Firewall, Is A Female Connector On A Short (approximately Three Inches) Pigtail With Five Wires. I Cannot...
Asked by
Dsims6465
2004
JAGUAR VANDEN PLAS
VIEW MORE
Cooling System Pressure Test
Change Oil and Filter Hyundai Tucson
Oil Life Reset Ford
