Can anyone help me with this query as I have made several attempts to find out what might be the cause, but have been unsuccessful?[/i:7eae3b9d8f][/color:7eae3b9d8f][/b]
Jaguar Windshield Misting and Wet Floor
thanx
thanx[/quote:6f7d134f44][b:6f7d134f44]
Thanks for both coments. I'll check it out and let you know the outcome. :) [/b:6f7d134f44]
Suggested Repair
Check the driver's side heater box drain, which one expert says is plugged. Pull back the carpet; it should be on the transmission tunnel near the gas pedal, and clear the drain so water does not enter the cabin and mist the windshield. Another expert suspected a leaking heater core, so if the fluid is coolant rather than clear water, have the heater core inspected as well.
Conversation Summary
The owner of a Jaguar reports windshield misting above 70 mph, a grey film starting just above the dash vents, an arch of condensation in the same area, a constantly damp driver's mat, and a clear water-like drip onto the left foot. No exterior leaks or holes were found. One expert suspected the heater core. A second expert said it is not the heater core and that the driver's side heater box drain is plugged, located under the carpet on the transmission tunnel by the gas pedal.
