front o/s window not working
1997 JAGUAR
85,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
RICHARDPUGH
front o/s window not working also central locking? tried new switch, got power motor works, is the locking connected to window?
Sep 11, 2014 at 8:51 PM
HMAC300
  • 48,601 POSTS
windows are not connected to central locking there are relays that are however but we are given no location for them. so check in doors. also have it scanned because it may be a body module problem.
Sep 11, 2014 at 11:37 PM
RICHARDPUGH
Hi thanks for trying to answer my question! But have sorted it, the windows are connected to the lock's i.e. when one locks the door the windows go up! That was part of the prob, as one of the switch's on the lock was faulty! So fixed switch and found that an fuse had blown! On one of the 5 fuse box's 5???? Any how it was simple, in the long run! Thanks for the answer so quick!As it was an jag, I thought it might need re-coding or something similar? That is why I asked for some info! But as normal it was something simple. I am an auto electrican by trade any-way, but this is the first time I have used an forum for advice, and I am very happy with your prompt answer Thanks yours Richard p!
Sep 12, 2014 at 2:08 AM
HMAC300
  • 48,601 POSTS
that's ironic because when I looked at the diagram I used an XJ6 and it showed no kind of system hook up to door locks oh well it's fixed.
Sep 12, 2014 at 2:26 AM
RICHARDPUGH
x300 3.2.jag?
Sep 12, 2014 at 8:45 PM
HMAC300
  • 48,601 POSTS
don't have that model in U.S.
Sep 12, 2014 at 10:35 PM
