2001 Other Jaguar Models transmission
JEFF SPONSEL
  • 2001 JAGUAR
  • V8
  • 50,000 MILES
I have a 2001 Jaguar s type with 50000miles on it. I get rattle out of the transmission when you put it in gear. I do not get it when I put in park unless I bring the rpms up over 3000 the flywheel is good does anyone have any idea what is the cause.
Thursday, January 10th, 2008 AT 1:41 PM
FSTRANGER302
  • 117 POSTS
I would check the torque converter nuts
they hold it tight to the fly wheel. On a 6 cyl there are 4 and a 8 cyl there are eight. It will rattle if the nuts are loose. Let me know if this helps. Rep points appreciated if this helps. Thanks
Saturday, January 19th, 2008 AT 1:26 PM
