1985 Jaguar Fuel Pump No Power
1985 JAGUAR
ELYSE
My friend has recently redone the engine. Now, the fuel pum p is not getting any power. Any ideas of what could have happend and what could be done to fix it?
May 1, 2006 at 3:44 AM
LOSONE
  • 1,616 POSTS
When the ignition is turned on the fuel pump relay energizes and applies power to the pump. Make sure all fuses are good. May be the relay. Good luck
May 1, 2006 at 7:16 AM
Suggested Repair
With the ignition on, confirm the fuel pump relay energizes and supplies power to the pump. Check that all related fuses are good, and test or replace the fuel pump relay if it does not power the pump.
Conversation Summary
After an engine rebuild on a 1985 Jaguar, the fuel pump receives no power. The expert explains that turning the ignition on should energize the fuel pump relay and send power to the pump, and recommends checking the fuses and the relay.
