Cranks no start issue
219,463 MILES • 2.4L • 6 CYL • 4WD
SUMMER MALVEAUX
Changed timing belt, tensioner, water pump, radiator and alternator. had to tow it twice in one week. fuses are good and it has power. so please let me know what to do.
Apr 21, 2021 at 2:35 AM
Did this no start issue happen after these repairs or did you make these repairs trying to correct it?
Here is a guide that will help with this to get us started:
https://youtu.be/dCjmRL3p4Cs
Also, does this happen all the time? Sounds like it is intermittent? If so, does it start normally and drive fine except for when this acts up?
When this acts up try using starter fluid in the intake and see if it starts. If not then we need to confirm this is a spark issue by removing the plug and hold it against the block and crank the engine to find out if we don't have spark.
Let's start with this and go from there. Thanks
Apr 22, 2021 at 10:54 AM
