It will not start by key in ignition, but does if bypass the started and block intake with a cloth filled with fuel. it then takes for a one minute but cuts out as fuel not coming through. Took it for a diagnostics test and all clear by them. Could it be starter relay or petrol pump relay? but could it also be the immobilizer/anti-hijack system? Thank you.
Oct 30, 2017 at 7:16 PM
