I do not have any access to specific information about your car, but I will try to help you troubleshoot it. To me, that does not sound like something that the immobilizer is doing. it sounds more like either (1) The battery is weak or cable connections are weak or (2) The starter itself is failing.
If you can do it and have the tools, you should start by checking your battery terminals. If you can move the cables where they are connected to the battery, then they are too loose. Simply tighten them up and see if that helps you.
If the cables are tight, find your starter and make sure the cables and bolts on it are very tight. Again, you should not be able to move the cables on that end.
Start with that and let us know what you find.
Jul 11, 2017 at 10:19 PM
